Noisy Printheads/Laserunits
  • Hansoon
    • Sep 2007
    • 3387
    Until now I always replaced noisy Polygon Mirror Motors in Printheads/Laserunits.
    Unfortunately at the time I face several BW Bizhub 350's with noisy laser motors. They are coming in abundance like rotten apples falling from a tree. Only last week I had three in a row.
    Did anybody have experience with cleaning the mirror shafts and bushings and slightly (VERY slightly) relubing the shaft of those noisy mirror motors? I tried one which is working fine until now but I have no long time experience yet. I believe that this problem is not limited to KonicaMinolta but will be broadly among all brands using the same technology.
    Hans
    • 23009
    Re: Noisy Printheads/Laserunits
    On HP LJ4 and LJ2200 printers, I've been cleaning the shaft, then taking a single drop of oil, wipe most of it off, then the remaining on the shaft. These HP's will go any where from 4 months to a year, before actually needing the laser replacement.
    I've never been into the KM laser units, so I can't tell you if the polygon mirror assembly will slide off the shaft. Some won't. =^..^=
    • Hansoon
      • Sep 2007
      • 3387
      They do. There's a tiny bracket under the mirror disc itself which keeps the rotor from spinning off. This bracket has only one screw to remove than you can take the rotor off. I did as you did: cleaned the shaft and bushing with alcohol and than a minuscule dot of oil the size of a speck of fly poop.
      Hans
        • 23009
        Let me know how well it lasts. =^..^=
