OKI C9600 Top Cover Open Error 310
  • owencom
    • 10
    I am getting the top cover open message on a OKI C9600 with error 310. Can anyone tell me exactly where the top cover switch is ? Can it be bypassed if broken ? I cannot see anything physically wrong with it but maybe I'm looking in the wrong place.
    • 23010
    Special Delivery!
    I had a similar experience on a 5200. This is quite a funny story.
    The printer had been shipped from a Florida office to Michigan. I would have liked to been there for this part: The UPS driver found the box a little heavy to lift, so he rolled the box end-for-end all the way across the parking lot, all the way across the lobby. The same with printer #2.
    You can imagine the kind of condition the machines were in. Both top covers were shattered into several pieces. All the LED assemblies on #1 were busted, the end pins on all the developing/drum units of #2 were all broken off, on and on and on. When I powered up #1 it gave a 310 code. The microswitch had moved close enough to the frame to short the terminals and blow out the 24vdc interlock circuit on the controller.
    In the end, I made one printer from the two + ~$700.00
    Oh, and thanks UPS.
    • owencom
      • 10
      I am hoping there is some way round it as it wont be worth spending the $ on a new controller as I am just using this as a test machine for refilling toners. I till cannot find the microswitch. Can anyone tell me exactly where it is or would you have a photo ?
        • 23010
        Sorry, my C9600 manual is corrupt-won't open.
        The front door microswitch is in the front right corner inside the engine controller box. You might have a bad microswitch. You might have a broken actuator in the top cover, or you might have a blown circuit on the engine controller. Since the manual won't open, I can't be positive, but I think this is the doorswitch: 42693501 Cover Switch.
