Panasonic DP2500 fuser code
  • REHOL
    I have a Panasonic DP2500 with a fuser code E04-01. Anyone tell me how to clear this code? Can it be reset? What causes this code?
  • The-Peanut
    • Aug 2006
    • 192
    Its fuser related
    check the fuse and lamps
    • REHOL
      I know it's fuser related. My question is, can you tell me how to reset it or does it reset once you find the bad part and replace it?
      • gordie
        • May 2008
        • 83
        Hi
        This might be some help?
        Code Function Check Points
        E4- 01 Fuser warm-up temperature 1. Fuser Thermistor is dirty.
        2. Thermistor position is incorrect.
        3. Fuser temperature is low. (Adjust F6-31)
        4. Thermistor is defective.
        5. Fuser Lamp connector is disconnected.
        6. Fuser Thermostat is defective.
        7. Fuser Lamp is defective.
        8. HTC PCB connector (CN716) is disconnected.
        Gordie
        sigpic
        • nmfaxman
          • 1702
          Have to reset in service mode.
          F9-06-04
          • just a tech
            • Jan 2007
            • 332
            Follow nmfaxman's instruction to reset. You'll be looking for the item labeled " LBP Fuser Reset "..
            • Naveed Shahid
              • May 2008
              • 162
              hello brother how are u
              E-04-1 i enter mode simulation with key ''Function + Original Size + 3 ''
              go to f9 mode ,06 (ram initialize ) sub code 04 te reset fuser error
