Panasonic DP1820e paper lift problem?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    new customer called and said machine is making a clicking noise and says add paper for tray 1 even though paper is in tray. I've only worked on one of these before to replace drum, etc. but hate to turn away new business. Sounds simple like a broken paper lift gear? Is there anything common with this model that would make a clicking noise and not lift paper. Like to have the part with me when I go to call.
    Thanks in advance for the help
  • birchcourt
    • May 2011
    • 20
    Re: Panasonic DP1820e paper lift problem?
    Take with you a lot of tape to repair the housing, otherwise replace the lifting assy
    Verstuurd vanaf mijn SM-A310F met Tapatalk
    • NIKROTAS
      • Feb 2013
      • 16
      Do you have also the error code E2-01? Check the lift cove motor, probably is broken. This damage is very common.
