Should i Buy Panasonic 8035
  • rizwan143
    • May 2015
    • 42
    [Misc] Should i Buy Panasonic 8035
    Hello Friends!
    I am back to photocopier world after 5 years. Bought a new shop in my town & started photocopier work 1 week ago with xerox 8045 but sadly its having many faults again & again in few hours. The Seller agreed to return the machine in exchange of Panasonic 8035.
    Guys is that a good option to use that machine as i have around 500 to 600 copies per day only. (mostly 30-40 copies in an hour)
    Also, the reading counter of that machine is around 7,00,000 . Is it worth for me to run it at shop.
  • driving lots of miles
    • Jun 2016
    • 383
    Re: Should i Buy Panasonic 8035
    Panasonic has not made any copiers for several years. Parts are hard or impossible to find and genuine toner is almost nonexistant. Copy count is on the extreme high end.
    • copiertec
      • Jan 2016
      • 2175
      What's worse then a Xerox? A Panasonic.
      • Mad_Coachman
        • 99
        Panasonics were easy to work on but they always needed work. Ricohs used to run from PM to PM but their quality fell off the cliff about 5 years ago.
        • Gab
          • Aug 2015
          • 634
          no Pnasonic stoped produced copiers years ago. You will have problems with parts and support
          • Samanator
            • Sep 2017
            • 562
            Even a Kyocera 3500i would be better than a Panasonic 8035.
            Hells bells, you can even get most parts for a Kyocera 3060 and that would be a step up from a Pana 8035.
            I outta know, I'm factory trained on both.
            Tell that guy he can do better and he knows it.
            • mojorolla
              The Wolf
              • 2551
              Had a school system with over 300 Panasonic 80xx machines; I still have trouble sleeping.
              The 8035 had the worst fuser of the series with a long web that stalled and a press roll which had the strength and integrity of a Jimmy Dean breakfast sausage.
              At 7 million it would make a nice addition to an extinct technology museum.
                • 22753
                13 years old and 7M copies? Don't do it. It's a boat anchor. =^..^=
                • rizwan143
                  • May 2015
                  • 42
                  Thanks alot for all the guys who did replied.
                  Unfortunately or Fortunately ( may be ) i have got the panasonic 8035 & its working almost fine. i am printing 500 to 600 copies daily on that. the only problem i am facing right now is
                  1) Its print gets weak after 3-4 days. ( I contacted Tech guy & he told me to go to F6 > 21 > & change the values to +22 & go to F4 & Run 051 for 1 minute) & the print gets sharp & fine for 3-4 days. Even he cleaned tonor sensors too but problem is still there.
                  But i am happy with PAN 8035 due to fast warmup time of less then 30 seconds. i hope to print around 30,000 to 40,000 copies & will cover the price of this machine. then i will buy Bizhub 601 in few months.
                  • MIGUELMARCHENA
                    • Feb 2018
                    • 174
                    • csliao
                      • Oct 2021
                      • 33
                      Originally posted by rizwan143
                      Hello Friends!
                      RICOH MFP parts and support easy get
                      • MadelSmith
                        • Sep 2021
                        • 3
                        Yes! This is a good buy. Cincinnati SEO agency
                        • rizwan143
                          • May 2015
                          • 42
                          Yes! 7 months passed!!! i did bought that 8035 & now i am very fine with that machine. though the speed is slow but not much maintenance required except routing cleanup of drum / coronawires after 20-25 days. rest its a very outclass machine
                          • KellyP
                            • Sep 2021
                            • 3
                            screen enclosures tampa
                            This is a highly recommended product. But something to take note about its cons:
                            • No USB capabilities make direct connection extremely difficult with a lot of newer PC's and laptops that no longer accommodate parallel interfaces.
                            • Scanning and copying resolutions are about average, limiting top quality production to documents that contain all text.
                            finger lakes real estate pelletized gypsum
                            • JohnMyers
                              • Jan 2024
                              • 1
                              I'm considering using the Panasonic 8035 for my business, as I only need to make around 500 to 600 copies per day. Do you think this would be a suitable option for my needs? I appreciate your advice and any insights you can provide. Handyman Sioux City
