DP4510 lead edge backgroud
  • Nieu
    • Jul 2008
    • 18
    I've got a DP4510 that gives a 1cm background on the lead edge of the copies.The rest of the copies are perfect.What could this be and what should I look for.Any ideas welkom
  • Vista Tech
    • 116
    Is it doing it from the ADF? If so adjust your ADF lead edge timing. If its only on the glass adjust your lead edge void. Both can be found in F5. Good Luck.
    • Nieu
      • Jul 2008
      • 18
      its doing it from both the ADF and the platen glass,but ill try anything thanks
      • The-Peanut
        • Aug 2006
        • 192
        this is a common fault on these models
        take the drum unit out, remove the drum and check the catch blade (below the drum blade)
        bend it back out or replace
        check the sensors that sit towards the back of the drum unit just below the catch blade
        check the transfer unit to see if u have a layer of toner on it
        remove the dev unit & place it on the desk, rotate it anticlockwise to seeif a layer of toner lands on the desk, u may need to replace the dev
        Hope that helps
        John
