panasonic dp 1820p
  • copicatt
    • Nov 2008
    • 366
    panasonic dp 1820p
    Not familiar with panasonic at all, this is my third in 15 years. This machine was purchased wholesale by the customer. It only has 15k on it, looks great. Works fine except for doing 2-2, the feeder jams every time. It will pull it in, scan the first side, shoot in back into the reversal tray, pull it back in, scan the second side, then it gets halfway back into the reversal tray. Is it supposed to go into the reversal tray after completion? or to the bottom? No idea........Help appreciated.
  • Urushiol
    • Sep 2009
    • 22
    All our 1820s in the field have platen lids, not doc. feeders, but if its like other pannies(2310, 3510, 8035, etc), it will.....
    scan the first side--->reversing bin--->scan second side--->reversing bin--->exit bin.
    What J code are you getting when it jams, J74 J73 etc? Is it crinkling or ripping the sheet, or does it simply stop feeding?
    Locate the deflector gate at the entrance to the reversing bin, its possible that the defector gate isn't moving to send the sheet exit tray after scanning the second side, it may be stuck/solenoid dead and its trying to send it to the scanner again.
    • copicatt
      • Nov 2008
      • 366
      I wrote the jam code down when I was out there last week, but misplaced it , darnit. J73 sounds right though. It looks to me like it should come out at the bottom, not in the reversal bin, maybe the gate is getting stuck. Looks like I need to find a manual, huh.
      • Bob Briggs
        Open the door under the doc tray and you will find a cream coloured guide bar which is actuated by a solenoid located at the front of the feeder, the solenoid is either jammed or the return spring is broken, so on the second pass the doc is getting re-guided back up rather than out, hope this helps !
        • copicatt
          • Nov 2008
          • 366
          That makes alot of sense. thanks very much, I will check it out.....
          • Bob Briggs
            No Probs Copicatt, let me know how you get on !
            • copicatt
              • Nov 2008
              • 366
              Good Job Bob! You were right, the the lever that the solenoid actuates was over the flap when it should have been over the flap. Thanks!
              • Bob Briggs
                No problemo Copicatt, nothing worse than standing over a m/c scratching your head (been there !), pleased it got you out a hole, take it easy !
                Bob
