DP-C262 error message E4-14 fuser fan
  • office machines
    • Aug 2006
    • 33
    I am having a problem with a Panasonic DP-C262 with E4-14 code, the fans are comming on and staying on. Has anyone seen this problem and is it something I'm missing..
    Thanks in Advance
    Sammy
  • jaybug
    • 25
    have you checked for pinched wires. could be the fanspeed feedback wire grounding.
    • suckis
      • Dec 2006
      • 165
      I face an E4-14 problem some time and I finaly replaced the fuser fan. The fan was working properly but I think that maybe it didn't take as many turns as it should, so the error code appeared.
      ! RTFM !
      My site: http://www.e-club.gr/
        • 23010
        I've seen this code before on a Rainbow2. Cleaning the dust bunnies out of the squirrel cage helps, but did not completely prevent the codes. Replacing the fan did the trick. =^..^=
        • JVergin
          Service Tech / IT Rep
          • 216
          There is a service bulletin about this. replace the toner motor fan and the IH fan with the new style. Its a weak solder joint that is the problem on one of the resistors.
          Once you replace both of these fans with the new style fan, this error code shouldn't come back.
            • 23010
            The fan I installed in a DP-C354 has begun to pull errors again. I installed (L6FCLDCJ0001). Is this old style or new?
            A google search brought up (L6FAKEDK0007). Again, old style or new? =^..^=
            • onetek
              • 318
              NEW part# for the IH/toner fan is L6FALEGK0012
                • 23010
                Thanks onetek. That was awfully nice of Panasonic to let me help them clear out the old defective stock from their shelves.
                I'll get it ordered right away. =^..^=
                • pana.techn
                  PANASONIC SERVICE TECHN
                  • Mar 2008
                  • 33
                  Do yourself a favour and replace both the 2 offending fans (fuser and toner fans) they are both bad after you replace these 2 fans you will be fine.
