DP-4530
  • joemamma
    • Sep 2025
    [Error Code] DP-4530
    Getting intermittent E03-25 which is drum motor rotation error. Wondering if anyone else has come accross this?
    TIA
  • sostek
    • May 2010
    • 81
    Saw this on a DP4510 once, it turned out to be the flywheel, which was loose and fell off! This was at around 1.2 Million copies.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • joemamma
        This machine has 440k on it and the flywheel was on tight. I did hear a little bit of grinding noise at the start of making copies for the first time late today. I'll be tearing into it Monday morning.
        • ineo+6501
          • Mar 2010
          • 262
          I've had this before when the blade has flipped
          • PanaTech
            • Dec 2008
            • 71
            Check the seperation wire and corona wire on the transport unit. IF that thing snaps, n short circuted that m/c, it will pop random error codes
            • pana.techn
              PANASONIC SERVICE TECHN
              • Mar 2008
              • 33
              Generic drum?????????????blade???????????? can you turn the drum by hand ( when the assembly is out) also a little smig of grease at each end of the drum may help but if its generic you are just asking for trouble
              Steve
              • joemamma
                Sorry I forgot to post the fix. It ended up being the drum drive motor. Once I replaced the old motor and turned it by hand after completely removing it from the machine I was relieved to see it didn't turn smoothly. The E03-25 eventually wouldn't clear out at all and it's been 1 month since the replacing motor. Motor was definately the problem.
