fuser lamp testing
  • MPM2140
    • Mar 2010
    • 13
    [Electrical] fuser lamp testing
    How do I test a fuser lamp on a DP1820 ?
    Have an E4-01, lamp or thermistor
  • 20gaugeO/U
    • 553
    Probably thermistor and/or the UFR has a layer of scum on it and needs to be replaced also. You can meter the lamp when it's out of the machine.
    • mojorolla
      The Wolf
      • 2583
      If you cheat the door interlock you should be able to see the lamps illuminate. It is most likely the thermistor. I have seen very few bad lamps on these.
      • delboy10
        • Jun 2010
        • 43
        Also, check to see any build up toner on the thermistor, make sure the thermistor is touching the hot roller. You can also measure the resistance of the thermistor. It is about 1.47 M ohms in normal condition.
        • suckis
          • Dec 2006
          • 165
          Did you try to LPB fuser reset?
          ! RTFM !
          My site: http://www.e-club.gr/
