i have an 1820 where the solenoid that releases the paper feed clutch is not acitivating after the first page is through, it works once than decides not to, i have to take out the duplex guide reset everything and than it happens all over again, any help would be welcomed because i am stumped, thanks.
1820 not feeding from bypass
I had several problems with 1520/1820s' bypasses. Most of them had to do with the bypass feed clutch (the spring inside the clutch was faulty).
! RTFM !
My site: http://www.e-club.gr/ -
Thank you foro your reply tommygun.
