PF7718 E3 code
  • axyun
    • Aug 2007
    • 1323
    PF7718 E3 code
    Customer called with E3 code. I was not aware at time that there is sub-code. Customer mentioned having just changed toner and making somewhat of a mess . I assumed connection between changing of toner,spilling of toner and error code. I vacuumed out machine which wasn't so bad. I cleaned transfer and main chargers and reinserted toner bottle. Still flashing E3 and I somehow did not see a sub-code but I am now wondering if it was an E3-03 and I thought it was just an E3 flashing as customer had mentioned .
    I see that if it is an E3-03 that would refer to toner density sensor. I am assuming machine was working before customer changed toner and that customer was responding to an add toner message. it doesn't seem likely that installing toner bottle even if incorrectly would do something to toner density sensor.Any help is appreciated. Frank/ActionPhotocopy
    • 23010
    There are too many choices to make an educated guess, without knowing the sub-code. =^..^=
    • axyun
      • Aug 2007
      • 1323
      All is okay now . Re-vacuumed hopper area,collar etc cleaned sensor and reinstalled toner making sure in correctly. Code had already reset when i got there and turned on machine so I still do not know what it was though I suspect it was toner bottle code now E3-01. Frank
