2310 fuser web advancing issue
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Hey, it's me again. I'm having trouble getting the webs to advance properly on some 2310 fuser units. I can't seem to get the tension right on the metal "actuator" as the service manual calls it. I believe there was a bulletin released related to this issue and I was hoping somebody could provide me with it. If I'm mistaken about the bulletin, then any advice you may have is appreciated as well.
    Thanks!
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • 20gaugeO/U
    • 553
    It is bulletin M-0180i. Email me if you can't get it and I'll send you a copy.
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      E-mail sent.
      O.o
      • onetek
        • 318
        Get last upgrade kit #PJZSF274EAZ.....
        Th.
        • TONERINMYNOSE
          • Aug 2010
          • 114
          When was this upgrde kit released? I still have many problems with 2330/3030
          • onetek
            • 318
            Some time around september 2009.
            • Waylon
              • Sep 2010
              • 26
              You may want to look into shanging over to the web advance drive used in the latest model of that series DP-8025/8032. There are too many variables with the original system, even with the bulletins changes it is stell prone to failure without unit specific adjusting/modifying to get to work. The new drive advancement makes use of a one way bearing instead of the metal spring tab ratcheting on a gear. I know a fuser from a DP-8025 will work in a DP-3030, but I have not yet tried intermingling the individual parts of the new and old model #'s but I think it will work.
              • TONERINMYNOSE
                • Aug 2010
                • 114
                Waylon do you have a parts manual per chance? I only have up to 2330/3030, thats when we dropped the panasonic line.
                • onetek
                  • 318
                  Fuser from a 8035 fits a 3030.The diffrance is also in the temperature management .
                  TH.
