pana 8045 not starting up
  • marra
    • Sep 2009
    • 4
    we have a pana 8045 in the field that when you turn it on the only response you get is a blank screen with the backlight on and the print data light on green. the fuser lamp comes on and the fan kicks in but nothing else can anyone help.
  • mojorolla
    The Wolf
    • 2583
    The hard drives on these machines cause all kinds of problems. Remove the back cover and disconnect the hard drive. You may also try powering up directly into service mode. If machine is cycling up, you may simply have a bad LCD screen.
    • The-Peanut
      • Aug 2006
      • 192
      i've popped out and had a look at this machine for "marra". there is no HDD installed, powering into service mode dont work either,
      the backround light is on, but no display, also the data light is on (no flashing)
      all voltages are correct from DC PSU, DRV, SC & PNL1
      it looks to me as if the machine aint got a clue what it is,
      looks like a SC board fault.
      • mojorolla
        The Wolf
        • 2583
        Yep. Sounds like an SC all the way. I have scene at least 2 that do odd things to the screen; even with proper voltages.
        • sostek
          • May 2010
          • 80
          Had an 8035 do exactly the same,turned out to be the PNL pcb(under the op panel), Also mine could print and copy but you could not select duplex,sort,etc.
          • mojorolla
            The Wolf
            • 2583
            You may also want to try the Master Firmware recovery procedure. If you cannot go direct into service mode, the boot Room is corrupted. The firmware will need to be flashed.
            • JustManuals
              • Jan 2006
              • 9838
              This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
              Paul@justmanuals.com
              • 20gaugeO/U
                • 554
                Check to see if the ENERGY SAVER key is stuck. Had this happen and the machine when turned on was looking for the Emergency Firmware Recovery sequence.
                • Logged-on
                  • Sep 2010
                  • 197
                  I'm going agree with sostek, I've heard of this once before, wasn't my call but, we replaced the pnl board, and it worked.
                  • The-Peanut
                    • Aug 2006
                    • 192
                    well guys, fault solved, it was the energy saver button stuck down, many thanks for all your help
                    John
                    • safos
                      • Dec 2007
                      • 13
                      Re: pana 8045 not starting up
                      and..
                      today I had the same symptom.with your help it solved.it was the ENERGY SAVER.
                      many thanks to all !!!!
