Panasonic DP-3510 Paper misfeeds from legal size paper tray only when tray is full.
  • erixpc
    • Aug 2025
    [Jamming] Panasonic DP-3510 Paper misfeeds from legal size paper tray only when tray is full.
    This DP-3510 has two paper trays. A letter size and a legal size. If I take out about a 1/2 inch of paper out of the legal size paper tray it works fine. Feed rollers were leaving a black mark on the top sheet in the tray so I cleaned them. They now feel clean and sticky but still having trouble. What should I do next?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • erixpc
      Thanks but I all ready have the parts and service manuals. If it was an old xerox machine, I'd know to clean or replace a feed clutch. Does anyone know if this machine works the same way?
      • Logged-on
        • Sep 2010
        • 197
        Really seems like an odd problem for this machine. I believe the lift motor kicks in, lifts the paper to the take up roller, and when it lifts the take up roller it activates a sensor and turns off the lift motor. So there should be a pretty consistent paper height no matter how much paper is in the tray. If you suspect it's the feed clutch, you could always swap tray 1 and 2 feed ports, just make sure you plug it in correctly.
        And if it's leaving marks on the paper, it seems to mean that the clutch is working, the rollers are trying to work, just something is preventing the paper from being pulled from the tray, maybe an actuator?
          • 23009
          Maybe the tray side guides or endstop are set too tight, holding the paper back? =^..^=
          • mojorolla
            The Wolf
            • 2627
            The black "lift flag" on the rear of the tray slips, causing the flag to give a false reading to how high the tray actually is.
