The machine will copy and intermittent the paper stops in fuser and half way out the exit. It calls for a misfeed U6 but it will do so a few copies from any tray is this a sensor issue above the fuser??
It sounds like a interlock switch on the right side of the copier. could be a lvps also. I check the manual there other thing too. But i would look at the switch first.
