dp 3030 misfeed
  • yannii33
    • 121
    dp 3030 misfeed
    the copier will print and copy and then when its idle for a few minutes it just starts on its own as if to print and then it shows misfeed in the fuser with no actuall paper in it. It just starts on its own . Cab someone pplease help with this thanks
  • Rick Martinez
    • Sep 2009
    • 77
    have you checked the error log? and if so what is the error code you get? i had this happen and i found out that the exit sensor flag is broken, you might want to check there.
    • mojorolla
      The Wolf
      • 2660
      Is this plugged into a network? I had one which would print random blank sheets due to a corrupted print driver. The paper would pass then throw a J01 or J31.
