KV S3105C Scanner U13 error...sensors check good, runs about 2 hours!
  • mjunkaged
    • 384
    I am thinking this is probably a long shot, but any Panasonic (or otherwise) technicians who have any experience with these scanners? NOW cust. also tells me it can happen at startup as well as after it's been running a while.
    Customer swapped his own lamps out, and after doing so receiving several errors: U12,13, 16, and others, but no F codes. I cleaned the lamp that was showing an error (he swapped front for rear) and re-calibrated shading plus 'adjust all' he's still coming up with just a U13 error so far, even though he scanned 4 folders full of docs before it failed. When the failure pops up, it won't even work with a single sheet, it goes into the error long before the paper gets to the conveyor section.
    I'm thinking bad PS or motherboard at this point, unless I can find a flaky sensor, pinched wire, loose ground etc. Sensor check shows them as good, i.e. '0' with no paper, '1' with paper blocking sensors in front AND back. So cust. checked all of them relating to paper jam 2.
    Also, is there firmware for this model, or just the EEPROM chip? From what I've read in the SM, it has no firmware update at all. If it does, probably burnt to a chip.
    HELP????
  • mojorolla
    The Wolf
    • 2627
    Re: KV S3105C Scanner U13 error...sensors check good, runs about 2 hours!
    Did you check the door sensor?
    Document Sensor Door & Home Sensor according
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • mjunkaged
        • 384
        Customer just bought it from you Paul!
        • mjunkaged
          • 384
          mojorolla:
          Done, done, done. Sensor always checks good. I went out this morning again, performed EEPROM initialize, and re-ran shading, adjust all, doc sensor.
          Now we are waiting and seeing. So far he has gotten other errors but directly attributable to the docs being scanned.
          No more U13 so far, still got a rear lamp warning, but it is old so he's prepared to order a new one if it won't stay gone.
          • mjunkaged
            • 384
            Paul: Do you have dell 5100c or know where i can get it? At the moment I only need the parts diagram. OOPS never mind, same as phaser 6300.
            Cust. should be ordering it shortly. I told them to get the one with all three models and email it to me. I'm assuming it's identical to the one that only has 6300+50 exc. for the extra model? Correct me if I'm wrong.
