Dp 405
  • otuvak
    • Aug 2010
    • 102
    Dp 405
    Have machine with E4-03. This is the second machine in two days. Replaced fuser in one and ordered another. The current one codes out and customer powers machine and it will work for a day or two. Is anyone seeing this problem? I already have a manual. Thanks for reading!
  • mojorolla
    The Wolf
    • 2639
    Re: Dp 405
    On the top of the fuser (at each end) are two spring and a cam that control pressure. They can break off at the anchor point or can be installed wrong after a PM or dis-assembly. Also, with the fuser out, there is small gear pack in the lower right, rear corner. Make sure there are no chips in the disk in that gear cluster.
