E04 01
  • darvs
    [Error Code] E04 01
    Hello guys, I have a problem with DP8035, I changed the fuser lamp single and put it error code E04 01, and I dont have handbook to solve it.
  • JustManuals
    • Jan 2006
    • 9838
    Re: E04 01
    This Service Handbook can now be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • doug94550
      • Dec 2011
      • 138
      Re: E04 01
      The E4-01 is the fuser not coming up to temp.Verify all of the connectors. Sometimes they can fool you. They feel connected but in reality, are not. Ohm out the lamp you installed to verify it is good. If so, you also have a thermostat and thermal fuse that could blow. Go ahead and ohm those out. If everything checks out, you probably have a blown thermistor. After that, go for the AC Driver board the big fuser connector plugs into. Good Luck but E4-01's are usually pretty easy.
      • mojorolla
        The Wolf
        • 2627
        Re: E04 01
        Before you do anything, go into F9 service mode and run LBP Fuser Reset. That will get rid of the code in most situations.
        • doug94550
          • Dec 2011
          • 138
          Re: E04 01
          Ah. Totally over trouble shot. What Mojo said.
          • Logged-on
            • Sep 2010
            • 197
            Re: E04 01
            We had an 8035 where the E4-01 kept returning, replacing the SPC board finally repaired it. Of course that's after running the LBP fuser reset.
