I have an 8045 with a cracked glass. The one used only when feeding thru the doc feeder. Looked in the parts book and it shows you have to get the entire exposure glass. I know someone out there has delt with this. I was thinking about taking it to a glass shop and have them cut me one. Anyone been down this road? Any ideas?
Exposure glass
Re: Exposure glass
Just make sure that the glass thickness is the same, and the edges smoothed but not beveled. In my experience every copier I've worked with has had a metric dimension, 2 or 3mm thick. Back in the moving tabletop days we changed quite a lot of glass. Not so much these days. It's usually pretty cat-astrophic if the glass is broken. Smashed DF, bent scanner, broken mirrors ...
=^..^=If you'd like a serious answer to your request:
ESTANISLAOWENENTON
