Panasonic DP-8060 Error Code J44 and Sometimes J50 exits fuser but error's out
  • sagar4
    • Dec 2012
    • 127
    [Error Code] Panasonic DP-8060 Error Code J44 and Sometimes J50 exits fuser but error's out
    I have 25 Panasonic DP-8060 Copiers and 3 of them are giving the j44 error code. Each machine has about 600,000 copies on it. I know the book says exit sensor. Does it mean the exit sensor on the fuser or the machine. Any help would be greatly appreciated.
    "Broken again"
  • copiman
    • Sep 2011
    • 861
    Re: Panasonic DP-8060 Error Code J44 and Sometimes J50 exits fuser but error's out
    SB-10-J50_Deformed_LeverPlate-(M-0210i)__DP-8060Series.pdfIn my experience I have had several things cause this. I am assuming that the paper is flat when you go to remove it. In other words, nothing physically stopping the paper.
    1. Customer pulling on exit door prior to opening front door. See attached bulletin. Also I have seen the entire exit door warp. If you have one from another machine try swapping.
    2. The springs on the inverter roller coming off. More likely the one on the front side of the machine.
    3. Exit sensor actuator get a nick, due to wear, and causes enough hesitation to call up jam.
    4. Pressure roller old. Maybe try swapping the fuser if you have one.
    Here is a link to search Copytechnet. Copytechnet Forum Search - Via Google
    That's all I can think of right now.
    • sagar4
      • Dec 2012
      • 127
      Thanks.
      Originally posted by copiman
      [ATTACH]22121[/ATTACH]In my experience I have had several things cause this. I am assuming that the paper is flat when you go to remove it. In other words, nothing physically stopping the paper.
      "Broken again"
      • mojorolla
        The Wolf
        • 2630
        Run copies from the platen glass and the document feeder. If it only jams using the document feeder, check the exit baffle solenoid and inspect the sensor inside the inverter as it tends to form nicks on the actuator surface.
        Platen copies exit fuser and go straight to the exit tray. Doc feeder copies exit the fuser, go down into inverter, and then to the exit tray.
        • sagar4
          • Dec 2012
          • 127
          Ok thanks.
          "Broken again"
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
            Paul@justmanuals.com
            • sagar4
              • Dec 2012
              • 127
              Thank you all for the response. It was actually a small spring on the exit sensor. When actuated it would go back up to slow. Removed spring tighten it up and wd40 and all is working and has not jam since.
              "Broken again"
