C406 Control Panel Dead
  • disko
    Copier Guardian
    • Jul 2014
    • 34
    [Dead] C406 Control Panel Dead
    Hello everyone, have a issue with a Panasonic DP-C406, customer stated the machine is dead, the control panel does not seem to be working. I went out to complete a service call. The backlight on the Control Panel seems to be the only thing working, everything else is blank and doesn't respond or make a noise. It won't receive faxes, prints, or do anything.
    I did swap out the control panel for another one on a working DP-C406 in the office but the same issue persists. I come from a Konica Minolta background on repairing copiers so any help would be appreciated.
  • onetek
    • 318
    Re: C406 Control Panel Dead
    Try disconnecting hard drive.
    • disko
      Copier Guardian
      • Jul 2014
      • 34
      Hard drive disconnected. Same issue. Just a blank lit control panel. Replaced hard drive with a new one. Same thing.
      Testing the sc PCB
      • disko
        Copier Guardian
        • Jul 2014
        • 34
        On CN58 pin #3 reads 3.46v not the suggested +5vdc would that be my issues with the SC PCB ?
        • onetek
          • 318
          Did you try starting with all options off?
          • disko
            Copier Guardian
            • Jul 2014
            • 34
            Tried that the same thing. Thinking about the SC PCB replacement with another machine we have in the service. Would you advise anything else before I deploy that option.
            • onetek
              • 318
              Its easy to swap, so give it a try.
              • disko
                Copier Guardian
                • Jul 2014
                • 34
                Replaced the SC PCB and its fixed, only issue i had was the settings in the machine we different. Took me forever to figure out how to remove the DEPT ID Code on the copier. Finally got it, thankfully the touchscreen works and issue is resolved (for now) .
                Thanks for the help!
