SC899 intermittenly when scanning to JPEG
  • krakchead
    [Error Code] SC899 intermittenly when scanning to JPEG
    Current firmware, new controller. Only happens when scanning to email with JPEG.
  • rosspt
    • Mar 2012
    • 92
    Re: SC899 intermittenly when scanning to JPEG
    Would really help if you listed the model of copier you are working on for us to help you. Without knowing any details the list is pretty long as to what could be causing your issue.
    Re-write all firmware - especially NCS and Scanner
    Replace HDD
    Replace Controller
    Replace IPU board
    Just out of curiosity, is the machine on DHCP? Very rare but I've had a machine try to connect with an email server on dhcp and have it cause sc899. Switching to static fix it.
    • krakchead
      Replace HDD
      Replace Controller
      Replace IPU board
      Of course, sorry the model would be helpful. MPC 305 .
      • anothertech
        • 1771
        Could you try down grading the system firmware.
        • fuwei2422
          • Nov 2014
          • 49
          SMB scan ; sc899 up the firmware is ok
