mp c5502b color black is missing
    • 37072
    Re: mp c5502b color black is missing
    Originally posted by billm
    Ok got the sp1103-2 printed and scanned to my lap top it looks good to me. I get the fact that you can not fix the customer and am willing to blame the file if only I had the same problem with different copiers. But it does print good on three others one was a MP C5502.
    [ATTACH]30465[/ATTACH]
    [ATTACH=CONFIG]30466[/ATTACH]
    [ATTACH]30467[/ATTACH]
    thank you for your support
    Printer SP 1103-002 will show if the problem is in the engine. If the problem is only when copying, we need to see a scan of the copy from something that we recognize, such as 1103-002, in order to analyze where the problem might be in the scanning or image processing of copying.
    Now take that printer SP 1103-002 and copy it. Attach both so we can see the difference.
    • NeoMatrix
      Senior Tech.
      • 3514
      [QUOTE=The CopyDoc;487479]
      Ya, Pick a picture on google without Macro setting! OMG Really!
      What is the above Macro image setting on Google you are referring too...?
      • The CopyDoc
        • Oct 2012
        • 19
        [QUOTE=NeoMatrix;487591]
        When you take a picture and the object is close and in the middle, but everything around the object is out of focus, like a flower, or a bee. The customer wants the copier to UN-blur the edges? Are you pulling my leg?
        • NeoMatrix
          Senior Tech.
          • 3514
          #19
          [QUOTE=The CopyDoc;487628]
          Okay.... Ah! yes the macro setting, like on my phone camera, I'm with you now.
          Macro as in lens ZOOOOM's in.....
          I thought you where talking about a hidden google browser setting....
          Solly olly.....
          • billm
            • Jun 2012
            • 50
            #20
            Originally posted by skynetto
            Had this problem once on a MP C2500. Had to Clear Settings on Printer SP: 1003 - 001.
            Use it with caution as it resets all the settings in Printer tab.
            did that no change
            • billm
              • Jun 2012
              • 50
              #21
              The problem is with printing only but
              here is what you requested
              • skynetto
                • Sep 2012
                • 257
                #22
                Print the non default SMC and do a Printer Application Clear in Copy SP: 5801-008
                Sorry to insist with this but the problem here is with the printer application or printer drivers.
