Faint Photocopies (Ricoh Aficio MP 3352 SP)
  • msquared840@gmail.com
    • Jun 2015
    • 29
    [Dead] Faint Photocopies (Ricoh Aficio MP 3352 SP)
    how are you doing guys?
    i am working on Ricoh Aficio MP 3352SP copier, and this is what it does;
    copying = Faint
    Printing = good quality
    Since the printing is okay, i don't think that it is a developing or drum unit.
    i have tried to change copying modes but it is only the "pale" at a maximum density can give me a fair quality copy
    what could be the problem?
    please help.
  • Elmo
    • Feb 2010
    • 541
    Re: Faint Photocopies (Ricoh Aficio MP 3352 SP)
    Yes it is the drum/developer had this many times
    you will probably get away with just replacing the drum then running set up
    but it is worth replacing the developer aswell
    what is the meter count if it is any where near the life time you need to replace them
    my advise is also to use only original parts
    I Used To Live To Fix Things Now i Fix Things To Live
      • Jun 2015
      • 29
      on average, how many pages does the original Drum Unit produce before you replace?
      • Elmo
        • Feb 2010
        • 541
        Ricoh recommended is 60K
        on average it seems to be more like 50K
          • Jun 2015
          • 29
          Now what do i have to buy to repair this Drum unit;
          OPC ?
          Developer ?
          does it also have Cleaner Blade ?
          • Elmo
            • Feb 2010
            • 541
            you can buy a complete unit
            or replace the items
            always replace the drum and cleaning blade at the same time
            attached is the service schedule
              • Jun 2015
              • 29
              Thank you Elmo ,
              i will let you know when i am successful,
              but the attached image is not opening. can you resend it?
              • jam-o-matic
                • Oct 2012
                • 72
                stating the obvious here - when internal prints are fine & copies are poor (light) optics are your issue. Just a cleaning of mirrors & glass, or a possible problem. You can also scan something to verify.
                • alphablaster
                  • Nov 2020
                  • 32
                  Hello and happy new year ! I have the same issue with an mp 3353, i have claened the optics but still the same. Could it be the led bar that has the issue ?
                  • davel
                    • Oct 2011
                    • 1107
                    You should have started a new thread, replace the PCU and dev.
                    • alphablaster
                      • Nov 2020
                      • 32
                      I did, excuse me. I have replaced them both but the same, printing is fine but copies and scans are still really faint.
