Ricoh 1515MF
  • Rick
    • Mar 2007
    • 277
    Ricoh 1515MF
    I have a Ricoh 1515 that is working perfect but is displaying message to replace the photoconductor. Is there a way to reset this message without actually replacing the unit ?
  • jjw23
    • Sep 2008
    • 36
    I was wondering the same thing. I have one asking for it also, but i'm not much into ricoh yet.
    • E Winter
      Isn't it enough to reset the PM counter?
      • jjw23
        • Sep 2008
        • 36
        no i tried that and it didnt work.
        • rthonpm
          • Aug 2007
          • 2859
          Try SP 5-912. Change the setting to 1 to disable the change PCU prompt from showing up. Essentially it turns off the alarm clock...
          • +ve charge
            • May 2008
            • 87
            Hi... Thank you for yr inputs into this thread. Pls let me know if resetting the alarm worked cos I too have a few of these that have not yet dispalyed the code, but I could be geared with this information when the code does come up. much obliged.
            • technthenati
              ricoh 1515
              /hi,
              Go into SP mode and go to sp5912-1 "alarm display on/off"
              enter 1 = do not display
              enter 0 = display
              that will keep it off permanently unless somebody changes it back
              if you just want to rest it and still prompt later when pcu needs replacing use sp7804-1 "reset pm counter" or 7992-4 "reset dev counter" can't remember which one did it.
