Ricoh Aficio 2035
  • tcypy1961
    • 773
    Ricoh Aficio 2035
    This Ricoh Aficio 2035 I've been working on has had a lot of SC-350 error codes. When I clean the copier and perform SP-3001 though, the copier starts working. Am I looking at an ID sensor that is going bad? Or could toner dust from either the PCU or Developing Unit covers be causing this issue? Thank you for any help given.
    • 36858
    Re: Ricoh Aficio 2035
    How have you been cleaning the ID sensor? If it is not cleaned properly, it will cause errors.
    • jonhiker
      • 661
      Exactly. Also, when was the last time a PM was performed. 350 codes can be caused by worn out drum and developer. When my group sees those, we just do a std maint of new drum and dv, etc.
      • Gab
        • Aug 2015
        • 657
        Also replace ruleman at drum unit.It also causes sc350
        • bob marley
          • Jan 2012
          • 1339
          Originally posted by tcypy1961
          Or could toner dust from either the PCU or Developing Unit covers be causing this issue? .
          That is possible
          I had a similar problem few years ago and was due to a defective I/O board
          Live for yourself and you will live in vain. Live for others, and you will live again
          • Iowatech
            Not a service manager
            • 3930
            Um, could you define what the ruleman is?
            It's probably a regional thing, like the osteopathic rhombus is here in my personal part of the periphery. Still, if you could let us know that would help all of us communicate more effectively.
              • 22934
              Spanish: ruleman
              English: ball bearing
              Greek: ρουλεμάν
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                I believe he is refering to the drum ground beaing on the drum shaft. A known issue also on these dirty pigs !!!!!!!!!!!!!
                Mystic Crystal Revelations
                • blazebusiness
                  SanDiegoCopierRepair.com
                  • 1250
                  Agree with the previous advice.....Assuming the drum surface looks ok and not coated with toner and copies look decent.......replace the drum and developer (or at least the developer) and you'll probably be done with the issue. Very common issue on the B079 series.
                  Proper way to diagnose this issue would be to check vsg/vsp/ and all the other various values in service mode
                  check drum ground continuity from bearing to drum shaft
                  verify it's not an issue with toner supply or toner hopper starving the dv unit for toner
                  That being said....just replace the developer.....bet that's the issue
