Ricoh MP C2051 unfused copies
  • mearmi
    • Oct 2010
    • 350
    [Misc] Ricoh MP C2051 unfused copies
    Ricoh MP C2051
    getting unfused copies randomly. Sometime it works for 2 days fine.
    Have replaced the fuser.
    please find the attached and advise.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Ricoh MP C2051 unfused copies
    Originally posted by mearmi
    Ricoh MP C2051
    Was it a new fusing assy or rebuilt?
    If rebuilt check the discharge brush....if new try firmware
    • mearmi
      • Oct 2010
      • 350
      Thanks for your response.
      fuser is brand new
      i m new to Ricoh Copiers. How to update the firmware for this model? Thanks a lot
        • 37641
        Check the pressure spring assembly on the side that is not fusing. Also check the pressure release arm on that side is not loose/broken/missing.
        • Jessetech
          • Mar 2014
          • 38
          Check gap on fuser do you see light also does it do it with different bond
          • mearmi
            • Oct 2010
            • 350
            Fuser is brand new. On both Fusers getting same problem
            New to Ricoh
            how to upgrade the firmware?
            thanks and regards
            • Chrief
              • Oct 2014
              • 30
              Stop copy midway through process and isolate if its from fuser.
              Also check if it applies to both mono and color.
              • sandmanmac
                • 3990
                It's a pretty safe bet that anything stopped before the fuser will be unfused
                • Iowatech
                  Not a service manager
                  • 3930
                  The firmware upgrade is a rather involved process that would be best left to a trained tech. If done incorrectly it can cause your machine to become a rather unique door stop. It would be better to eliminate all possible physical defects before trying that.
                  For example, are you using Ricoh toner? After market toner sometimes will cause this, but not always.
                  Thick paper can cause the problem you have described too, if the machine is not properly set up for it.
                  (Also, incorrectly labeled paper will cause this as well, a fact that causes me a great deal of irritation.)
                    • 23010
                    Originally posted by Iowatech
                    ... It would be better to eliminate all possible physical defects before trying that.
                    That was my first question: Are the correct media types being selected? =^..^=
                    • Klydon
                      • Mar 2009
                      • 243
                      Just going by his picture, it looks like the middle is what is having issues being fused, not the edges, so that sort of rules out the springs to a point. (Usually one side or the other is not fused when that is the case).
                      Could check fusing temps for the middle and maybe pop that up a few degrees to see what happens. I assume the machine is using the correct media setting (thick paper if thick paper is being used, etc).
                      You could also run the paper through short edge feed and see what it looks like. (The one shown I am pretty sure is long edge feed).
                      • mearmi
                        • Oct 2010
                        • 350
                        Ricoh MP C2051
                        Have replaced the New Fuser. tried on Thick 100 gsm and Normal 80 gsm.
                        • hillbilly
                          • Mar 2011
                          • 7
                          Had this issue, was advised by Ricoh to change the following settings worked for me
                          SP 1-105-003: default 131, new 145;
                          SP 1-105-004: default 95, new 100;
                          SP 1-105-007: default 136, new 150;
                          SP 1-105-008: default 95, new 100
