Model names
  • mikadonovan
    • May 2008
    • 2931
    Model names
    Hi, guys. Can anyone direct me to a list of model numbers to model names like, apollan, martini, metis etc. Thanks, Mika. Btw, whoever decided to go from a perfectly good drawn parts catalog to a 3D pos needs to die. Pretty much. Just sayin.
    NEVER ASSUME ANYTHING
  • skynetto
    • Sep 2012
    • 257
    Re: Model names
    Amen brother.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: Model names
      I think BLACKCAT has names for several manufacturers - he ought to be checking in soon.
        • 23008
        Re: Model names
        Naturally, I couldn't make up my mind what the best format would be. So I have files in Excel 2003, Textpad, and PDF. Personally I tend to use the Excel files because they are so easy to edit and organize. If size is a factor, the Textpad file is the smallest.
        If I recollect correctly this is the Excel file, since it requires zipping to upload.
        To anyone reading this post, please inform me of any identified mistakes, misspellings, and missed entries. All my files are works-in-progress, and being edited frequently to improve each day. =^..^=
          • 37490
          Re: Model names
          The names like apollan, martini, metis, etc were originally engineering code names intended to keep competitors from knowing exactly what they are developing.
          • sandmanmac
            • 3981
            Re: Model names
            This is BEAUTIFUL! Thanks CAT!
            • rthonpm
              • Aug 2007
              • 2854
              Re: Model names
              My wife works for a manufacturing company in new product design. When she first took the position, it was always strange hearing her talk about all of these codenamed products. Even better was when we would see one in stores and she'd be able to say what the original code name was so I'd know what they had been talking about for months beforehand.
              For myself, I can remember playing with early builds of Vista that still had the Longhorn code name.
              • NeoMatrix
                Senior Tech.
                • 3513
                Re: Model names
                Bugger... Now I have to add another column an Xref settings to the GooseGuide.xls
                Nice work though BC.....
                • HDSB
                  Field Tech
                  • Feb 2013
                  • 64
                  Re: Model names
                  Diana is named after Princess Diana, I was told on a course in Wellingborough that when the first one rolled out it had a picture of her in the plastic square on the front door.
                  • bob marley
                    • Jan 2012
                    • 1339
                    Re: Model names
                    good work, thanks
                    Live for yourself and you will live in vain. Live for others, and you will live again
                      • 23008
                      Re: Model names
                      Does anyone have anything to add? =^..^=
                      • Moza
                        • 232
                        Re: Model names
                        Just pulled this from the latest TDC if your interested Ricoh Xref.zip
                          • 23008
                          Re: Model names
                          Thanks Moza. =^..^=
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Re: Model names
                            Thanks for the update Moza.....
                            I'll put the info into the next revision of GG.
