Scan to Folder Mac OS 10.11 Using MPC4500
  • mrfuser
    • 1613
    Anyone know why we can't get scan to SMB Folder to work on the MAC ? It is SMB Compliant and we set up a shared SMB Folder.
    Kelly
  • ApeosMan
    • Nov 2009
    • 183
    Re: Scan to Folder Mac OS 10.11 Using MPC4500
    I don't know too much about Ricoh's, but I imagine this MFP doesn't support the SMBX protocol that the Mac OS has been using since 10.7. SMBX supports SMB v2 so if the MFP supports that then all should be good. That being said hopefully Apple hasn't changed things yet again with the SMB protocol.
    You may need to try FTP:
    ::: Lion FTPD Enable :::
      • 37364
      There was a custom firmware released for OS X 10.7 & 10.8. You might need to install check the version of NCS on the MP C4500. This is a different custom firmware than the one for Windows 8 and server 2012. This one has a later release date so it may also work with Windows 8 and Server 2012.
      B222_NCS_v5.20_LRC0355 Temporary SMB function (Scan and Fax) Problem regarding MacOS X 10.7 & 10.8 problem
      • jonhiker
        • 661
        The latest MAC OS do not support SMB scanning. Neither Ricoh or Apple have fixed that issue.
        • mrfuser
          • 1613
          Actually the latest has smb complaint
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Also be sure that if you are using a host name to scan to, that the Mac's host name is no more tHan 15 characters.
            I forgot what it is for Windows, other than it's greater than 15.
            If the Mac has its IP address assigned by DHCP, you may be forced to use the host name.
            If if the address is static, use the IP address.
            • Codex
              • May 2008
              • 701
              i tried for months, but the easiest way is scan to FTP, its very easy to setup, the only thing you have to do is to enable the FTP SERVICE on the MAC, with one of the enabling tools, then you can create a new user for the scans, or use the current user, i experienced that if you try to scan in a folder it doesn't work, even if the folder is shared in the network, but if you scan to the users Home folder it works without problems!!
              Memento Audere Semper
              • Codex
                • May 2008
                • 701
                To setup the MPC, try the following, after enabling the FTP SERVICE on the MAC:
                - go to the scan settings on the MPC
                - go to insert destination manually
                - press FTP (default is SMB)
                - SERVERNAME : mac's IP ADRESS
                -PATH: insert NOTHING here
                -USER: mac username
                -PASSWORD: users password
                thats all!
                • Cipher
                  It's not easy being green
                  • May 2006
                  • 1309
                  There is a way to get scan to folder to work on OS X Yosemite and El Capitan, but not for the MPC4500 as that model is too old.
                  It involves disabling SMB signing on OS X via the terminal and increasing the SMB authentication level on the MFD via telnet.
                  But generally it's far easier to configure and use Scan to FTP as mentioned above, and that will work with the MPC4500 to.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    I had a similar issue recently where we needed to disable SMB signing on a Linux based ( just as Apple OSX is) NAS server.
                    It took a Wireshark packet capture to find the problem, and even at that the problem wasn't obvious.
                    • logrady2331
                      • Feb 2011
                      • 301
                      Cipher is correct on the MPC4500. You have to edit the registry and disable SMB security vie terminal commands. Same with enabling FTP. However the mpc4500 WILL NOT WORK WITH sMB ON mac O/S Yosemite and up. FTP is crazy simple - but NOT secure.
                      • mrfuser
                        • 1613
                        Thanks for that information
                        This is for a client who just uses it in his home office just Him
                        • mrfuser
                          • 1613
                          Does the MPC4501 have the same problems?
                          Thanks!
                          K
                            • 37364
                            From the text file that comes with the firmware I mentioned earlier:
                            The following SMB-based GW functions will work with OS X 10.7 & 10.8 with these firmware.
                            - Scan to SMB
                            - Fax Folder Transmission (SMB only)
                            - Fax Forwarding (SMB only)
                            Cause:
                            Mac OS X 10.7 doesn't respond to the SMB command "SMB_COM_OPEN_ANDX(0x2d)". This is used by our devices to write files to destinations. Instead Mac OS X 10.7 requires that we use the SMB command "SMB_COM_NT_CREATE_ANDX" instead.
                            Limitation:
                            - The username and password that will be used to access a Mac OS X 10.7 destination will need to be input manually at the operation panel before browsing to that destination. The limitation will not apply to earlier versions of Mac OS X.
                              • 37364
                              Thanks!
                              K
                              Firmware for the MP C4501 to scan to MAC OS X 10.7 & 10.8:
                              System/Copy 3.06
                              Network support 10.63
                              This is regular production firmware.
