MPC2003 printing Dark
  • tsbservice
    Field tech
    • 7945
    #31
    Re: MPC2003 printing Dark
    Originally posted by patterson70
    Hi, could you tell me what the ACC is? I've got a MP C2003 with light prints that was fine not that long ago. Also is the Full Color Calibration the same procedure as in the User Tools, then Maintenance section, then Auto Color Calibration?
    Originally posted by mga
    What's pm lifes
    I really don't understand when techs hijack old threads with different problems. I mean Mark asked very basic question which should be 100% clear before even asking.
    Common is that hard to start new thread with few words properly describing the problem
    • patterson70
      • May 2010
      • 596
      #32
      Helpful, all. I replaced the black drum and did all the procedures posted, all is well. The drum must have been the major culprit as suggested. Only has 54K but black was barely legible. I know the max life is about 50K and they are not kidding!
      • patterson70
        • May 2010
        • 596
        #33
        It was just a question about about what ACC meant, that was all. I bid you a good day.
        • tsbservice
          Field tech
          • 7945
          #34
          Good you have found the culprit. We always hope for parts go some more, in my reality consumables are cause of 90+% of image troubles.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            #35
            So did you just replace the drum cylinder or a new oem pcu
            Regards Mark
            • patterson70
              • May 2010
              • 596
              #36
              A new OEM PCU.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                #37
                I find these machines very reliable the bk oem pcu is 60k pm life they always go way over what's the other parts life have you any samples
                Regards Mark
                • patterson70
                  • May 2010
                  • 596
                  #38
                  It is low mileage, the color drums are in the 30K range, so they have some life left. I wasn't sure it was the black drum because the customer called and said the prints were so light you could barley see them, so I thought it happened suddenly. Turns out they just did not get around to calling for a long time after prints started getting light.
