MP2851 capacity exceeded
  • GeorgeBest
    • Jul 2009
    • 526
    Hello,
    Customer with an MP2851 scan full color, 600DPI , A3 original.
    When doing that he gets an error saying that there is data capacity exceeded problem.
    Not sure, but is there a BIT-switch adjustment to increase the capacity when scanning large format/600dpi ?
    Thanks in advance
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP2851 capacity exceeded
    Are they scanning to folder or email?
    Go to User Tools > Scanner Features > Sends Settings > Set compressions to their highest level, and disable Max Email Size etc.
    • GeorgeBest
      • Jul 2009
      • 526
      Both . . .
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It's been a really long time, and I may be totally off base, but as I recall, there were some functions (such as what you are trying to do) that require optional RAM to be installed.
        I know of no bit switch that would resolve this.
        • hdmr
          Helpdesk Engineer
          • Feb 2013
          • 51
          I didn't think this machine would need additional RAM as it comes as standard with a HDD.
          Is the percentage indicator on the top left of the Scanner Screen going to 0%?
          • rthonpm
            • Aug 2007
            • 2854
            Lower the DPI on the scan or try using the WIA scanner interface from a desktop which allows you to scan in a higher resolution using file formats like PNG.
              • 37491
              Also is the memory percentage at 100% when you start the scan? If not, there is something remaining in memory from a previous scan.
              • teebee1234
                • Jul 2008
                • 1670
                I believe you're exceeding the buffer limit with that setting. There is a chart somewhere in the knowledge base that shows the relationship between resolution and scan size. I know A3/11x17 @ 600dpi is an upper limit. As others have said, max out compression and/or lower the resolution.
                • Captain Scott
                  • Dec 2008
                  • 166
                  I think I have looked into this before and it's a limitation. Think it's in the ops manual or service manual. No A3 600dpi
                  • anothertech
                    • 1769
                    Did anyone ever find this on paper? I have a customer that does not want to take my word for it that it's a limitation.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      I just checked the spec section of the service manual and there's nothing written other than the max res being 600dpi.
                      I'll take a quick look at the user guide for you.
                      • teebee1234
                        • Jul 2008
                        • 1670
                        Check this out
