I replaced drum, developer and blade and executed the proper sp modes.
After the replacement, image at the upper side for about 7cm is light.
I cleaned optics, laser unit , used an other opc drum, checked separation .
Also i checked developer distribution on magnetic roller and looks ok.
I executed sp 2 802 and 2 801 with no result also i noticed when i try to make darker the image
it doesn't has any effect on image. I think to replace developer (again) Any idea?
