MP2501
  • Gab
    • Aug 2015
    • 671
    MP2501
    I replaced drum, developer and blade and executed the proper sp modes.
    After the replacement, image at the upper side for about 7cm is light.
    I cleaned optics, laser unit , used an other opc drum, checked separation .
    Also i checked developer distribution on magnetic roller and looks ok.
    I executed sp 2 802 and 2 801 with no result also i noticed when i try to make darker the image
    it doesn't has any effect on image. I think to replace developer (again) Any idea?
  • StephenB
    • Aug 2015
    • 244
    Re: MP2501
    Just chased my ass for a couple of months. There are these new "dark greenish" compatible drums sold by several suppliers. most of the time they set up fine, but quickly go to poor density.
    I had the same thoughts as you, proper set up ? bad dev ? Turned out to be bad drums.
    Hope this helps
    • Gab
      • Aug 2015
      • 671
      Re: MP2501
      Hope this helps
      I have tried with an OEM OPC drum (now ihave OEM one in the machine ) with no result.
      I also have tested machine with a whole drum unit from an other machine (which machine has made only 15k copies and OEM OPC) , the same no result.
        • 37503
        Re: MP2501
        OEM does not mean Genuine Ricoh.
        • Gab
          • Aug 2015
          • 671
          Re: MP2501
          I mean the whole drum i tested is the drum machine had when i sold it and it has 15k copies
          so it is genuine Ricoh.
          Also customer told me that before drum developer and blade change image had only dark lines and after service light image at the top appears.I think he is right but i can't remember for sure. Except drum unit i haven't touched anything else on the machine.
          • Elmo
            • Feb 2010
            • 541
            Re: MP2501
            check the optics make sure you havent knocked a mirror out of position
            I Used To Live To Fix Things Now i Fix Things To Live
            • Polo-022
              • Sep 2007
              • 486
              Re: MP2501
              ""Except drum unit i haven't touched anything else on the machine.""
              Oh Yes you did Gab...you "touched" Laser Unit!
              Why?
              • PinevskiS
                • Jul 2009
                • 283
                Re: MP2501
                Clean laser unit (polygon mirror motor)
                and you have great copy.
                  • 8161
                  Re: MP2501
                  If the fault is happening on prints you can rule out the optics.
                  You have swapped another drum unit, so you can rule that out.
                  It can only be the laser or the dust glass did you clean the dust glass?
                  • PinevskiS
                    • Jul 2009
                    • 283
                    Re: MP2501
                    I have this problem many times ,problem is polygon mirror motor
                    • Gab
                      • Aug 2015
                      • 671
                      Re: MP2501
                      Why?
                      Because i believed it was the only thing that left The problem happens before itouch laser unit
                      andremad exavtly the same after.
                      • Gab
                        • Aug 2015
                        • 671
                        Re: MP2501
                        No deference when printing or copying
                        I have cand laser unit (glasses and polygon mirror motor ) also blow it with air. Noticed no deference.
                        • PinevskiS
                          • Jul 2009
                          • 283
                          Re: MP2501
                          Can you send scan of counter.
                          • Gab
                            • Aug 2015
                            • 671
                            Re: MP2501
                            Also i have swaped a separation roller from an af 2018 i had available with same result.
                            • Iowatech
                              Not a service manager
                              • 3930
                              Re: MP2501
                              First, the caveats -
                              I am not trained on that model,
                              I prefer to see an example of at least the print defect, as the different patterns that problems produce make it far easier to troubleshoot.
                              As such, what follows could be a waste of time, and I apologize in advance.
                              However, on older versions of the Ricoh 22 to 30 cpm chassis, the drum discharge PCB was on the upper left side of the PCU cavity, and if it was obviously contaminated with toner this sort of print defect would sometimes occur.
                              I suppose you might also check the drum ground, but as drum ground problems normally affect the entire printed area that is not very likely.
