Metis Paper curl.
  • Larhal
    • 571
    [Jamming] Metis Paper curl.
    Is any one else going nuts with the paper curling on the Metis series?
    New fresh paper, Curl after 4 hrs. Anti-condensate heater on but cold????
    ARRRGGGH!!!!
    Ricoh had a better idea, Drive service engineers nuts.
    Larhal
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • Zaxxon
    • 608
    Re: Metis Paper curl.
    No, only finisher jam but not alot.
    what Jam code do you get?
    Please start you post with brand, model, problem.
      • 37490
      Not had any problems. New fresh paper does not equal high quality paper or proper storage. Only time I had curl problems was a machine out in a corrugated steel shop building. During cold stormy weather, the first 10 -12 pages would curl up into 1" diameter tubes. Since it was not used for fax, I told them to remove the paper and store it in a plastic container over night.
      • Iowatech
        Not a service manager
        • 3930
        Some old news, it used to be a good idea to tell people to load paper in machines with the seam side of the ream wrapper up. Due to one part of the standard way paper is manufactured, curling would be somewhat less prevalent then, although bad paper would always curl too much.
        I actually haven't seen the curling issue for some time, but it seems to be making a comeback, though. I've seen a lot more damaged ream wrappers around here lately, and that's death for paper. At least when run through machines that use a thermal fusing process.
        • copier tech
          • 8144
          I'm seeing this a lot, especially as now the driver default to duplex, so every print is being double side.
          The only real fix I have found is tell the customer to use thicker paper, 100gsm seems to work perfectly.
          • ayeright
            • Feb 2011
            • 74
            See more of this as customers use cheaper paper to save costs. Sometimes helps to turn the stock to landscape and let auto rotate take care of things but it's easy enough to confirm if the stock is the culprit - pick up a ream of decent stock on route to the recall
            Tray heaters used to switch on only when the main power switch was off so didn't help if the machine's usual environment was cold/damp. Haven't looked at how the current range's heaters are set up.
            Btw, be careful with 100gsm. That falls into the 'middle thick' range so if you run it as plain paper you run the risk of offsetting and screwing up an expensive fuser. If the customer uses 100gsm, set the paper tray on the copier to the correct type and use the auto tray switching feature to get around paper type mismatch's on print jobs (user's don't like/forget/can't be bothered changing paper types in the print driver).
            • Larhal
              • 571
              Ayeright you are so true about the user cant be bothered to do the correct thing in the settings. they complain about CQ due to fuser offsetting and are printing 120 gms paper with 60-81 gms settings. Duhhh!
              Larhal
              Larhal
              • Polarbear
                • Feb 2012
                • 1070
                You could try the curling correction sp (SP1113) to ON "2" setting.
                I find it interesting that on EVERY paper type temp setting they suggest lowering fusing temp IF curl occurs.... Do they know there is a problem??
                1113 [Curl Correction] 001 Execute Pattern
                *ENG [0 to 2 / 0 / 1/step]
                0: OFF
                1: ON(No Decurl)
                2: ON
                Enable/disable curl correction.
                Press the GREEN button!!
                • tonnerboy
                  • May 2011
                  • 212
                  There is a MTB that recomends to Replacing the exit rollers with the modified ones;
                  Part numbers D2024456/D2024457
                  • Larhal
                    • 571
                    Thank you tonerboy. they are ordered and will be replaced.
                    Larhal
                    Larhal
                    • Captain Scott
                      • Dec 2008
                      • 166
                      Had quite a few recently. If the anti curl doesn't improve things. Try turning 1113 back to 0, then go to SP1105 and then drop settings 1 through to 8 by -10 degrees good luck
