Ricoh Aficio 2232C - SC393-01
  • metrombs
    • Sep 2025
    After fixing this error code, thxs to LVSB ( below) the copier takes forever in copying and doesn't to anything.
    Now what can that be.
    Thxs,
    Rad
  • lvsb
    • Aug 2008
    • 70
    Rad,
    An SC 393-1 is a black TD sensor error during warming up.
    • metrombs
      Got it, the toner sensor that grips the tblack toner bottle wasn't making contact. Now the copier get to ready , but when press to make copy y stays in copying .
      thxs,
      Rad
      • lvsb
        • Aug 2008
        • 70
        Rad,
        Can you print a SMC report?
        After pressing the start key is the original being scanned?
        My first thought would be hard drive and/or firmware
        • metrombs
          The original is been scanned, but if I send anything to print like the SMC it like freeze and stays there thinking.
          • rthonpm
            • Aug 2007
            • 2860
            Hmmm... Does the K dev unit work to drive the transfer in this model?
            How many pages are there on the K dev unit? Look at SP 7-803-006 to look at the PM counter for the unit. If it's past its yield, replace it and see if that does anything for you.
            Also make sure the MUSIC firmware is up to date...
            • metrombs
              now the copier is giving me SC-552 error code
              • rthonpm
                • Aug 2007
                • 2860
                SC 552, put a new fuser and oil unit in the machine. Make sure to clear the PM counter with SP 5-999-009. Also, check all of your connections to the controller just as a precaution. It sounds like something a little flaky is happening to the poor machine.
