how i can force toner in Richo MP c4500
force toner
Re: force toner
Sp 3015 Forced Toner Supply
001 Execution: ALL
002 Execution: COL (MCY)
003 Execution: Bk
004 Execution: M
005 Execution: C
006 Execution: YLive for yourself and you will live in vain. Live for others, and you will live againComment
Re: force toner
If you are going to do it, print a test, force toner just once and then print another test. If image density does not change, you most likely have a bad toner pump. If it does change, you need to determine why it is under toning and correct that problem. The machine will then tone itself back up.Comment
