force toner
  • feroo666
    • Dec 2014
    • 23
    force toner
    how i can force toner in Richo MP c4500
  • skynetto
    • Sep 2012
    • 257
    Re: force toner
    Sp3015
    • bob marley
      • Jan 2012
      • 1339
      Re: force toner
      Sp 3015 Forced Toner Supply
      001 Execution: ALL
      002 Execution: COL (MCY)
      003 Execution: Bk
      004 Execution: M
      005 Execution: C
      006 Execution: Y
      Live for yourself and you will live in vain. Live for others, and you will live again
      • anothertech
        • 1771
        Re: force toner
        Don't do it!
          • 37544
          Re: force toner
          If you are going to do it, print a test, force toner just once and then print another test. If image density does not change, you most likely have a bad toner pump. If it does change, you need to determine why it is under toning and correct that problem. The machine will then tone itself back up.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Re: force toner
            could it be that he's using aftermarket toner?????????????????
            Mystic Crystal Revelations
            • Zaxxon
              • 608
              Re: force toner
              Broken pump
              Please start you post with brand, model, problem.
