Mpc3003 waste boxes
  • Leebs14
    • Feb 2014
    • 457
    Mpc3003 waste boxes
    Can you empty these tanks?
  • Klaus Joergensen
    • Mar 2013
    • 5
    Re: Mpc3003 waste boxes
    I would not do that. You will stand in a ugly cloud of toner dust.
    Ricoh did not make a hole to empty them.
    Merry X-mas
    • Bantams
      • Jun 2012
      • 603
      Yes remove the four screws on the top and the tape that seals around the edge you will need to replace the tape afterwards I use Electrical tape .
      • zed255
        How'd ya manage that?
        • 1024
        Yes as above, BUT the screw and coupling are more delicate than those of the past. I had a client get wise and empty one and the drive coupling failed shortly thereafter resulting in a totally bound up waste toner system.
        Ricoh wants these replaced, not emptied. They are supposed to be a customer replaced item now.
          • 37362
          I just tape the slide door thst the waste toner enters through open.
          • sharpmind
            • Sep 2009
            • 478
            I use 3M vacuum cleaner in emptying the waste toner box.
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              If you empty them - empty it fully & reset the counter as I'm informed it can screw the waste section up I.e it overfills the waste, takes out the drums, belt, waste coil. We advise customers don't touch it just order a spare.
              i haven't witnessed it yet but I've been told it happens when it's partly emptied to get working.
              Incontinentia Buttocks
              • ronbo4114
                • 6
                it is easier to tape the shutter open and just empty it out then untape the shutter.
                • Athlontini
                  • Jun 2012
                  • 269
                  I empty them but it's definitely more of a pain than the older style. If you don't tape the shutter open you can get waste toner all over yourself in a heartbeat - and trying to vacuum them will kill a filter for me almost immediately.
                  • copier tech
                    • 8132
                    I had a customer break off the WT full actuator on the top, WT then backed up & damaged all 4 drums.
                    They are only cheap & hold a lot of waste so don't need replacing too often I just keep a couple spare in the car.
                    If the customer calls up with the waste toner near full message just ship a new one out & tell them how to fit it, simple.
