Mpc4500 disable energy saver auto off?
  • mrfuser
    • 1626
    We have a client that needs the machine to not shut off. Any ideas how to disable energy saver?
    • 37623
    Re: Mpc4500 disable energy saver auto off?
    User tools - System Settings - Administrator Tools - AOF
    • mrfuser
      • 1626
      Will the unit stay on and cycle every so often? That's what we need it to do to keep itself warm as it is in a cold environment.
        • 37623
        Auto off timer is disabled. Panel off mode (Energy Saver) is still active. After energy saver timer, max 240 minutes, panel will turn off and fusing unit temperature is reduced.
        If they want to keep the rest of the interior of the machine warmer you will need to install the Anti Condensation Heater (Scanner) and Tray Heater.
        • mrfuser
          • 1626
          Anyone have part numbers for the tray heater and anti condensation heater?
          Kelly
          • anothertech
            • 1771
            So there is no way to disable the energy saver mode?
