Ricoh 3045, SC322
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Ricoh 3045, SC322
    Don't know Ricoh's that well. From what I read the SC322 code is related to Laser unit? Any help appreciated.
    Thanks in advance
  • bob marley
    • Jan 2012
    • 1339
    Live for yourself and you will live in vain. Live for others, and you will live again
    • Athlontini
      • Jun 2012
      • 269
      Re: Ricoh 3045, SC322
      If you work for a dealer, I recommend springing for a complete laser unit if you can. Troubleshooting laser issues on boxes this old is painful.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4723
        No, I don't work for a dealer. I'm an Indy working mostly on Kon/Min equip. Hate to turn away business when sometimes it can lead to an upgrade.
        I have the 3045 SM and looks easy enough to pull the laser unit out. Was going to try cleaning the laser unit and reseat all the connectors? Are you saying that is a waste of time and laser should be replaced?
        • Zeldaman
          • Mar 2011
          • 946
          • hossam
            • Aug 2010
            • 70
            Pull out the laser unit, disassemble it, clean inside and mirror, blower it, take out the LD board you will find a sticker covering a lense inside clean it, perform SP 2-109 to adjust the laser beam pitch (described on the SM).
            Sent from my GT-I9300 using Tapatalk
            • TonerMunkeh
              Professional Moron
              • 3865
              Don't forget the door switches above the fuser. Changing the laser won't cure the 322 if they are faulty.
              Hit it.
                • 37533
                There is a quick to test if the door switch is flaky. Identify the connector on the LD unit and jump it. If the code goes away, the door switches are flaky.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Yeah I've seen more dodgey door switches on this model than faulty laser.
                  • hossam
                    • Aug 2010
                    • 70
                    may you please explain how to do that?
