MP201 with wireless card
  • copier tech
    • 8103
    #16
    Re: MP201 with wireless card
    I bought this little TP-Link router, it is tiny & works a treat, I fitted it to an mpc305, however as it is powered by USB when the printer goes to sleep it cuts the USB power so the router turns off & the customer cant print untill they manually wake up the copier (rather than simply sending a print job) thats the only drawback.
      • 36835
      #17
      Get one of the AC adapters for charging devices using an USB cord.
      • copier tech
        • 8103
        #18
        Hi yes I thought about that, but I wondered if theres an SP mode that one can set to keep the USB ports live when machine is in sleep mode?
        • pppp
          Technical specialist
          • Sep 2010
          • 43
          #19
          I find that issue depends on machine type. I am almost sure that bigger machines (I mean medium speed 30-50 copies) have continuous power in the usb port. In the box you should found white in colour power supply unit.
          Microsh.t is finished and Linux Rulez
          • pppp
            • Sep 2010
            • 43
            #20
            This is a good top using the micro wifi router! I understand if customer connects to the micro router they'll see the printer & can install it, but how would I configure it so that it connects to the customer main wifi network?
            Tp-link wr702n probes network at start. When another dhcp server acts in the network, the wr-702 works as a dhcp client and can be configured under received IP. From copier/printer point of view is transparent. Of course we talk about client mode. When wr-702 do not detect any DHCP server, one become dhcp server.
            So,
            when wr-702 is connected directly as P2P (straight cable - no network), one acts as a dhcp server and your computer gets IP from. Mini router can be very easily configured.
            • dzewo
              • Oct 2013
              • 36
              #21
              I concur with with PPPP. TL-WR702N is a really good choice. Small, easy to configure, looks neat when taped to the side of a device. Just run in client or repeater mode and that's basically all.
              • pppp
                • Sep 2010
                • 43
                #22
                I have verified usb power supply issue in the MPC2050 and power is permanent even in sleep mode. I use wr-702 and MPC2050 in my company without any problem.
