Ricoh MP-C3300 not detecting ethernet
  • roman2304
    • Oct 2013
    • 30
    [Misc] Ricoh MP-C3300 not detecting ethernet
    Hi everyone.
    I have a RICOH MP-C3300 with this problem...............the green led on ethernet connection never gets lid.
    I can program every setting (IPv4, Subnet, Gateway, DNS, SMTP, etc) and i can access the machine via WIM and can change every option but when i try to install the machine on a PC or Mac, the PC does not detect the port and dont install the machine (i hace a postscrip 3 option on the machine also).
    Any ideas?????
    Thanks!!!!!!!!!!!
  • skynetto
    • Sep 2012
    • 257
    Re: Ricoh MP-C3300 not detecting ethernet
    Is 802.1x enabled? If so disable it.
    • NeoMatrix
      Senior Tech.
      • 3513
      Then power the MFD Off, then back On.
      • anothertech
        • 1771
        When you are installing the print driver, uncheck the Query the printer box, then enter the IP address of the printer.
          • 37529
          I have found with Windows 8, 8.1 and 10 and I think maybe with 7 that you do not want to let the add print wizard auto detect anything. On the first add printer screen, "The printer I want isn't listed" even if it is. On the next screen select "Add a local or network printer with manual settings."
          • banginbishop
            grumpy old git
            • Oct 2007
            • 894
            I had a similar issue on a mettis- turned out to be a bent pin on the port. Hooked up a laptop and you could access WIM but still wouldn't print?
            Incontinentia Buttocks
            • Elmo
              • Feb 2010
              • 541
              if you can print via usb
              then i agree with banginbishop most likely a bent pin in ethernet port had it several times before
              as the port is soldered onto the controller it is a pain to replace
              an alternative to replacing the controller is to fit the optional gigabyte ethernet card used when fitting the e-3100 fiery
              (G178 6033 PCB:GIGAETHERNET:PCIE)
              I Used To Live To Fix Things Now i Fix Things To Live
              • Polarbear
                • Feb 2012
                • 1070
                Was this machine new? If not did it work before?
                Have you tested the machine with a cross-over cable to a working laptop/pc?
                Have you flushed all the settings back to factory and started from scratch?
                Press the GREEN button!!
                • Brianneoe
                  • May 2015
                  • 322
                  Make sure IP Sec is inactive.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    I had that exact problem a few years ago, I think it was a C301 at the time.
                    Drove me nuts until we found it.
                    • anothertech
                      • 1771
                      I had that problem last week, the IP was set to 192.168.1.201, but when I printed the config sheet, the IP showed as 11.22.33.44, everything else was 0.0.0.0, found the answer in goose guide. I left the Product Family on "all" and searched the Problem Desc
                      for
                      IP ADDRESS SHOWING ON CONFIG PAGE AS 11.22.33.44
                      • Jude
                        • Oct 2009
                        • 256
                        anothertech, would you care to elaborate since I do not have access to the goose guides.?
                          • 37529
                          It is posted here on CTN.
