Ricoh MP4001: Error while accessing Web Image Monitor
  • zeeaxis
    Manager TSD
    • Nov 2008
    • 28
    [Misc] Ricoh MP4001: Error while accessing Web Image Monitor
    Dear All!
    I 'm having a little problem that i have never faced before i.e., when i try to access Web Image Monitor on my Ricoh Aficio MP4001, my browser gives me an error stated below.
    Server has a weak ephemeral Diffie-Hellman public key
    Now, I have looked it up at various forums, but all that comes up is related to websites SSL/TLS certificates, and some changes you can make to your browser as a way around to avoid subject problem. If anyone has found a solution to this or even faced this issue, it would helpful if you could share your experience here. Thanks in-advance.
  • Iowatech
    Not a service manager
    • 3930
    Re: Ricoh MP4001: Error while accessing Web Image Monitor
    Originally posted by zeeaxis
    Dear All!
    If possible, post this here:
    http://www.copytechnet.com/forums/ri...tetner-lanier/
    That's where all the Ricoh techs hang out.
    There is at least one thread there that may have already dealt with that issue.
      • 8132
      Update all the firmware & also try another web browser, Chrome for example.
      • NeoMatrix
        Senior Tech.
        • 3514
        You may like to try login into the WIM with "Https://" instead of "Http://".
        HTH
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          This happens on the newer versions of IE. Using another browser should get around this.
