sp c242sf density sensor
  • ABS tect
    • Sep 2013
    • 511
    I have a SP C242sf and it is constantly requiring me to clean the density sensor. I open it up, slide the little blue arrow, clean it, shut it, it goes away, but then eventually it comes back up. Any reason why it keeps coming up? Is there like a reset code you have to perform on it?
    • 8163
    Re: sp c242sf density sensor
    I had this exact same problem, so manually cleaned the sensor with a can of compressed airi
    • ABS tect
      • Sep 2013
      • 511
      Did that do it for you? I have also done that
        • 8163
        Yes, but maybe theres an option to turn off that message in user tools also?
        • Counsel
          • Aug 2011
          • 529
          If its bad enough I usually pull the pcus, remove the ptr deck, remove fuser, take out the transfer belt unit and clean the od sensors with alcohol on a Qtip, vacum the machine real good, empty the waste bottle etc. I also proper replacement of PM parts when at yield such as the transfer belt/cleaning unit help keep it running cleaner. I really did care for these models much the pcus would not last as long as they should and the fusers would go out often.
          • rhe
            • Feb 2013
            • 51
            This error is due to laser unit, clean it or replace it
              • 37508
              Sounds like you need to be working on the toner scattering problem you have from using after market toner and developer.
              • rhe
                • Feb 2013
                • 51
                NO issue with the toner actually dust particles gets enter in the laser optics which should clean carefully or replace it without disturbing the mirrors.
