I have a problem with a AF 3260c color copier. The machine has got 320k scans on the black PCU. When you make a copy you get small dev. spots, which rubs off, on the copies. I did do SP3820 002 and SP2111 001 after replacing the drum. I found some dev. on the dev unit mylar aswell as in the cleaning unit. The drum now has scratch marks on which was probably done by the dev in the cleaning unit.
Any ideas?
Any ideas?
