MPC5502: SC544 M0264371 part
  • fshead
    • 2372
    #16
    Re: MPC5502: SC544 M0264371 part
    i made a jig up with a mini side door switch and an old thermister end connector"think it was a 3pin" and security wire.
    It took a bit to trip out code at least on this machine.
    I dont think i could fit that other one in my tool bag, so mini one serves my need and stays in my bag in case i see that again..
    I also now copy the nvram for all my 02s i service and keep them on my laptop just in case
    • fuwei2422
      • Nov 2014
      • 49
      #17
      when the machine tall sc542 544 code fist:5810-01 02 sec:if not reset the machine you must rewrite the BCU NVRAM and install the machin NO.
      thank you
      • ridgemill
        • Sep 2017
        • 184
        #18
        thank you
        Or, use the reset fuse / switch and two wires, and then use SP5-810-02. If you are gettings these service codes, then the fuser sleeve is most likely damaged, thankfully a new sleeve comes with a reset fuse.
        You ever need to replace the NVRAM to reset a fuser service code.
