Image shift when using staple function
  • illude2
    • Mar 2016
    • 30
    [CQ] Image shift when using staple function
    We have a Ricoh C4502 that will shift the image to the right around 1/2 inch but only if we use the staple feature. All other copies have normal margins. It has to be a setting but we can not seem to find it.
  • jam-o-matic
    • Oct 2012
    • 72
    Re: Image shift when using staple function
    Are you sure it is the staple function causing this? I know the duplex has an 'offset' & I usually zero out the 'margin shift' settings that are defaulted when running Duplex, thru User Tools.
    Is the shift lead to trail? or side to side?
    • Counsel
      • Aug 2011
      • 529
      There is some settings that usually we 0.0 out before it goes into the field but sometimes its forgotten. I think its under user tools, copy/doc server feature. Edit tab, there are a bunch of margins in there.
