Aficio MPC 3000 " You don't have privileges to use this function"
  • tamboknon
    • Sep 2015
    • 62
    Hi Sir, Just want to ask how to clear or reset this " You don't have privileges to use this function. Because I will reconfigure the IP ADD. TIA
    • 37442
    Re: Aficio MPC 3000 " You don't have privileges to use this function"
    Login as the administrator. Default is admin and leave password blank. It is the same credentials you use in WIM.
    • tamboknon
      • Sep 2015
      • 62
      Sir I press User tools>System Setting>Administrator tools>Administrator Authentication Management and "You don't have privileges to use this function" still appears. I think I'm the 3rd customer engineer who handle this unit in our office.
      • gear13z
        • Sep 2011
        • 68
        press User tools> before going to system settings, press the login/logout button on the rightside of control panel, just above the simplified display, below main power button, then you can see the login menu. username-admin, password-leave it blank or if not working type password.
        .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
        • tamboknon
          • Sep 2015
          • 62
          authentication failed... how can I reset the admin in the service mode Sir?TIA
          • copier tech
            • 8136
            Press yellow, 1,4,3, stop, then hold stop
            Sp5846-46 This will reset the default admin log in but it will also clear the address book.
